Cowl Interchange
dusted72
Thanks Hemiroid!!!!
Triangle, V.A.
Is the cowl, core support, and inner fenders from a 74 Valiant the same as a 70-71 Dart?
Pass inner fender is different, drivers side is basically same. Both will work. The 74 will have some AC component reliefs in the pass side inner, not present onthe70-71 inners.
Core support has some minor difference but would work.
Cowl depends. Are they both two doors. Also look at the lower corner, need to be the same style, both should be pointed in the corners.
