Crack on block
It tell you man, if that IS a through crack, that's gonna be a LOT of drillin and pinnin. LOL
Clean around the cracks inside the freeze plug holes, maybe sandpaper, then put dirty oil on it, then tap it with a hammer, then wipe it off, then tap it again. The oil will go in and out of the crack and show a line.
From the only picture so far, I don't think it is either.
In that gash there is a hairline crack in it,probably will have to welded.it doesn't go all through but it's cracked in one side of freeze plug hole.where cracked started or something.its thin in that spot
I'm just gonna let a machine shop fix it,it crack in a thin area in freeze plugs location.
I took it to the machine shop today it can be welded and fixed the gash hairline crack it has in pic.there goin to do a pressure test as well on block.
