monoptn
Mopar Aficianado
I understand that Nostalgia Wheels is planning to make a limited production run of Cragar SS wheels with A body bolt pattern and backspacing. They are going to run 14 and 15 inch.
I called the other day to preorder, and the guy there seemed pretty knowledgeable. He said that I could fit a 15x8 under the back of a 72 Demon. Is this right, and if so, what tire could you put on it?
Incidentally, the 15s will be about $169/wheel.
