twayne24365
would y'all be able to tell me if my crank is drilled for the STD pilot bushings or will I need the bearing?
I would recommend you measure it with some calipers to verify. It's very difficult to tell from a photo!would y'all be able to tell me if my crank is drilled for the STD pilot bushings or will I need the bearing?
I'll post measurements tomorrow!
thanks
I'm definitely going to indicate the QuickTime bell...
going to my buddies to finish milling out my shifter bracket, and chuck up the rear oil galley plugs in the lathe and mill them down a little because the block plate hits them
How did you do that?
Lol, Not a lot of folks have gauge pins handy. You might try something close and a feeler gauge to get a better read on the dimension.but the best i could come up with is .895.
