1. mocar
    mocar Well-Known Member
    75
    2
    Apr 13, 2014
    shorewood
    Local Time:
    9:48 PM
    . Trying to put in my 4 speed tranny, but I'm about 5/8 of a inch from bolting up to the bell housing and tranny won't go in any further. I installed a new pilot bushing into the back of the crank. I installed the bushing flush with back of the crank flange. My question is this the right depth? I'm 99 percent sure that the old bushing was flush .also, or is there something else that the tranny is bound up on. Clutch alignment tool goes right in,
  2. Marcohotrod
    Marcohotrod Well-Known Member
    2,121
    478
    Mar 21, 2015
    Massachusetts
    Local Time:
    10:48 PM
    is the diameter of the alignment tool any smaller than the trans shaft? did you test the bushing on the trans before install? the bushing installed depth should be o k cuz the trans shaft can go in with plenty of room to spare, the bushing depth does not need to be perfect.
    • Like Like x 1
    • DrCharles
      DrCharles Well-Known Member
      438
      157
      Jun 7, 2012
      West Plains, Mo.
      Local Time:
      9:48 PM
      I got to this exact point with my first 383 build many years ago, and the trans wouldn't go all the way in. Fortunately I had the engine and trans on the floor, not in the car... I found that the crank hole, although drilled to the proper size for the bronze bushing, wasn't deep enough for the input shaft! Engine had come from an automatic car.
      It was easy to make it just deep enough with a hefty drill motor and a drill bit larger than the input shaft but smaller than the machined area.
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      10,453
      1292
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      9:48 PM
      or u could cut some off the input shaft , lots of ppl have done it if u find out u don't have enough depth in the crank..............kim.......
    • Marcohotrod
      2,121
      478
      Mar 21, 2015
      Massachusetts
      Local Time:
      10:48 PM
      the o.p. said he replaced a pilot bushing, so the crank is maybe drilled deep enough
    • DrCharles
      438
      157
      Jun 7, 2012
      West Plains, Mo.
      Local Time:
      9:48 PM
      Maybe.
      I didn't say so explicitly, but my crank was deep enough to install a new pilot bushing, but still not deep enough for the input shaft.
