[WANTED] Crank pulley for a '90 360
Pulled the crank pulley off of a '74 318 and the bolt holes don't line up. Anyone have a crank pulley that will fit a '90 360?
Thanks.
What you are encountering is you have one part with symmetrical bolt pattern and the other with offset/non-symmetrical bolt pattern....
Try to line up the holes by hand and find the best fit... There will be one hole that overlaps the other almost by one half while the others are pretty close, just get a die grinder and oval out that hole so it will line up with the other one and you can use what you have and be able to install all 6 bolts...
Make sure to use a washer on the bolt for the hole that you egged out....
Been there, done that....
I'll have to try that. Thanks.
