Crap in the fuel line !!!
'70_Duster_340
Connecticut
I took the advice and installed a new gas tank in the 70 Duster ... I disconnected the line at the fuel pump and blew it out for a long time with compressed air .. There is still fine particles acumulating in the gas filter, so I'm wondering, what next ??? Looks like a real pain in the butt to replace the stock line with all the bends...
Anyone have any suggestions ???
Thanks
Kenny
I'll try to search it out, but the above link goes to a drapery place !! LOL ... Do the lines you are talking about follow the path of the stock ones ?? Man, they weave in and out everywhere ....
The trick to flushing such a line or even a heater core is the go both ways.
Disconnect both ends and blow it out again from both ends. The fuel is washing it too and the particals will end or tiny pin holes will develop in a totally rotten line. Good luck
Thanks guys, for the link and tricks ... I did blow the line out when I pulled the old gas tank out. from both sides ... I've had the car indoors for nearly 30 years, so the line is not rusted out, but I learned a valuable lesson about letting a car "sit" for too long a time ...
Today I replaced the fuel pump and she is running better, but still has a bit of a skip to it ... Since the tank, sending unit, pump and filter are new, I'm thinking maybe the carb is messed up from all that sitting around, so I'm going to do something about that next... not sure whether to have the stock AVS re-built, or spring for a new Holley .. any thoughts ?? I can't remember the details of what was done to the engine, as it was back around 1980 or so, but I remember buying a purple shaft cam and lots of other direct connection parts and had it re-built by a local guy who is great ... He estimated that the 340 was making around 375 hp at the time, and I've only put a couple thousand miles on it in all this time ... I should also mention that I had to replace the pushrods, and a few were bent up pretty good, one so bad we had to cut it in half with a die grinder to pull it out without taking the heads off .. The heavy duty valve springs all seemed to be fine .. I've put in new plugs, wires, coil, control module ... etc .. but still that skip .. I'm beginning to get frustrated !!
The fuel line literally rusted istelf almost shut on my '71 New Yorker. Took me awhile to figure out why it was starving for fuel at higher throttle levels. Once they start going bad it is best to just replace.
That's the frustration I went through ... The car would idle and run "normal" ok, but literally died when I mashed the gas ... After changing the filter 3 times I decided to replace the tank .. Good thing too, because some really putrid stuff came out of that old tank ... I changed the filter again today, and there was some, but not a whole lot, of sediment in it .. I'm gonna try driving it for a few days and see if the filter plugs up at all .. At least now it will take full throttle and keep running ...
