Craver lug nuts
indian
battlefield mo.
Need some help identifying correct lug nuts for my cragers.going on my 64 dart
I believe the current Cragar number is 9005-4, but that is for right hand threads. If you still have left hand thread lugs on the driver's side, I'm not sure those are available any more.
If you still have small bolt pattern, they`ll be 7/16-20 tpi, straight shank with heavy washers. R+L hand threads.
Agree.
Look like 5 on 4 to me, so you'll need mag shank style lugs for 7/16-20 with probably small diameter washers. Shank length determined by the thickness of the wheel center.
Left hand thread versions are probably not available anywhere, so if you still have lh thread studs, you'll need to change em .
