Creeping dipstick on /6?
jwsjp90
New Member
Philly
74 Dart Sport 225 /6 1bbl. I'm getting oil all over driver side of engine compartment (under hood, tip of the air cleaner, and power steering lines) can't seem to figure out why? I had somebody else work the throttle while I watched and it appeared that maybe the dipstick creeps under load? Anybody else ever had this happen? The heat riser also look oil soaked too.
My old Ford 6 cyl truck did that. I'm sure there are other things that can cause this,but in that case it was a crack in a cyl. wall.
if your pvc system is not working or clogged you force any blow by or pressure out of the dipstick tube or out the breather . make sure your pvc is in good working order and not obstructed going to the carburetor . i believe the only other thing it could be is blow by from the crankcase from the rings going bye-bye
