63dartman
I am going to replace my cam sometime in the future to wake up my engine a little and wondered if this would be a good choice for a street and occasional strip car.
Beast Hydraulic Cam
1750-5750 RPM Range
288/298 Adv. Duration
444/467 Gross Lift
360 with speedpro pistons zero deck
eq magnum heads 10:1 compression
750 eddie/ rpm airgap
3:23 gears
904 with stock stall(also going to uprgrade and need to know what is a good stall for this cam that will have good street manners. Willing to give up a little performance for streetabilty) Here are my current cam specs:
Lift: .454''/.475''
Duration: 256°/262°
RPM Range: 1000-5500
Beast Hydraulic Cam
1750-5750 RPM Range
444/467 Gross Lift
3:23 gears
Lift: .454''/.475''
Duration: 256°/262°
