custom dash layouts- Show us what ya got!
3d printed cluster and a 5" tach Mount to fill in the cut up dash.
It is very interesting! Good job! I also have a printer and have thoughts about printing a few other pieces for these mopars! If it works out I might try to sell some of the parts.
I don't want to get off topic too much, if you're interested in 3D printed stuff, check out the forum section. There's a thread with more details and CAD files for the cluster I made in there as well.
Original stopped working. Sold it here a while back. Fabbed this one out of aluminum and then blew it apart trying to tack it together with my flux welder. made it again with sheet metal and gently tacked it then used filler and jb weld where it blew through because of my bad welds. Dealt with some old melted wires. Corrosion at the headlight switch turned it into a toaster. Soldered across the adjustment sping contact in the switch so now the inst. lights just go on or off not adjustable. The speedo is GPS. Replaced the oil light with a mechanical gauge but I might put a Tee/sensor on the cable so the light comes back into the cluster.... The angles on a dart cluster were really tricky and I notched the OEM cut-out to drop the custom gauge shape so its more visible. The OEM is very narrow and didn't allow good visibility of the giant speedo I put in. the zip-ties were replaced with black tape once everything was double checked.
Good morning all! Doing a major overhaul on my 73 Scamp and looking to see what some of you are doing for dash modifications. Being a "Kustom is the only way" kind of guy, My car is by no means "stock" and have the interior completely out of the car dong a major interior upgrade. I have the dash pulled for a repaint and rewire, stereo install, Intellitronix gauge panel, a/c upgrades and steering column. The dash pad will be wrapped with contrast stitching along with full custom interior treatments. Just curious what some of the rest of you are doing to upgrade, update the factory parts and pieces.
Not "custom" by any means, but I love the gauges. Auto Meter American Muscle.
Autometer bezel with Autometer classic Mopar gauges.
The autometer setup looks really nice for sure! It's interesting how just a change of gauges makes a difference. Yours and Mopar603 look quite a bit different than each other even tho the base panel is the same. That's the definition of Kustom: different than stock or the next one!!
I just printed this one for my 69 Dart, not done installing yet. White gauges are before black gauges are what I’m going to. This let me incorporate my switches into the dash and get a radio back in the car.
