Im looking for a stroker piston in the 12cc range is there any way to get custom pistons without going over 500? Or a way to get a 17cc piston to 12cc ?
Machining a 17cc top will cost compression height meaning you either have to cut the block decks a like amount or run a thin gasket. And you may run into valve clearance issues depending on cam spec/timing.
Why not follow Brian's recommendations from the other thread and call it good?
