1973 Scamp that is my hotrod and not a race specific car. It has full interior, etc. RB 512ci, 440 source stroker kit with lightweight crankshaft, forged pistons, 10.83 CR. Trick Flow 240 heads, 440 source aluminum rockers 1.6 RR, Trick Flow single-plane intake. Holley Super Sniper EFI, HyperSpark ignition, coil & distributor. TTI 2 inch headers. Hughes 3000 stall converter. 727 transmission with Transgo TF2 valve body mods. B&M Quicksilver shifter. Gear Vendors overdrive to 8 3/4 rear end with 3.91 gears, braced in back. SS leaf springs.Viking Warrior shocks. Pypes exhaust 3" into 2.5". RacePro mufflers. Mickey Thompson ET street SS Drag radials 275/60-15). Current cam specs 244°/252° @ .050”, 282°/290° ADV, .516”/.537” lift (1.5:1 rocker), 112° LSA, .016”/.018” lash, Solid lifter from Oregon Cams.
I took out the x pipe as I needed some room for the gearvendors install. So my exhaust goes straight into the racepro mufflers. The car runs great at the moment. Our last race was 11.46 at 118. Prior to that we were at 11.7-12 sec. Amateur drivers here so there is much to be improved on. Launch and strip manners are good.
I know the cam is not ideal for naturally aspirated without nitrous as it was designed for a bit of boost. This may happen but not this year as I do not want to put a rollcage in. I would like to have consistent 11.50 time.
SO.... Would the installation of cutouts provide a bit of an advantage to take the 11.8s times to be more in the 11.5 times? I would never run open cutouts on the street. Older video of my exhaust sounds.
Last years race.
Last years race.
