It appears the BHJ damper on the stroker engine has slipped, perhaps up to 10 degrees. It has only seen 6 years of service. What brands do you guys prefer for small block applications? :scratch:
I'm using a BHJ on my stroker also. It's only a year old but I hope it lasts longer than 6 years. I was told that BHJ are rated as one of the better dampers so I went with them.
Not sure which brand I'll go with if I have the same problem that you've had.
