Dana 60 backing plates help!
duey_roc
Rancho cordova
I'm getting ready to buy this duster that's already back halfed. It has a dana 60 with a 4 link and coilovers setup. My question is this. It needs backing plates and brakes. Can I use the backing plates and brakes from an 8 3/4?
if the dana is a dana from a car,,or if it were a truck dana housing converted to car bearing ends which it probably is,,yes they will interchange u will need the drum that go to those backing plates,,car bearing ends are 5 bolt truck 4 bolt flange,
