aacwilliams
Active Member
I have a Dana 60 out of a 1968 Ford pick up. I want to cut it down and put it in my 68 Barracuda. I have a hanger\ shackle kit that moves the leafs in half an inch. I need to know if there are a set of measurements that I can use. Flange to fange length and pinnion offset. The machine shops that i talk to say that i need the wheels and tires and leafs in the car so i can take measurements. I am looking for a standard set of measurements so i can fit the larges rear tire that i can on the car without the tire hitting the body. I would like info on wheel offset if you have it. Thanks.
