[WANTED] Dart rocker clip
IIRC there are two on the front fender then about 1 per foot from there.
So 8 or 9 per side (just a guess)
Do you have the holes? I have measurements for the two on the front fender.
I hope you find the clips
The below info came from another member.
This is pertaining to the upper fender top moldings: (the clips are available repo)
"I counted the clips and or holes on the sides. The front fender has 6 holes. 5 of them are the plastic clips. 1 of them in the middle gets a clips with a threaded stud on it.
Door has 7 holes 5 are the plastic clips and the two outers are the clips with threaded studs.
Quarter panel has 12 holes 11 are plastic clips the very last hole on top of rear quarter gets the threaded stud clip"
This is regarding the rocker where it attaches to the fender:
Fenders get two clips. Both 1 7/8 0ff from bottom of the fender . Driver side fender looking left to right the first hole coming off the wheel well is 1 7/8" the second off wheel well is 4" both 1 7/8 " off from bother of fender going up.
I'll look for a photo of my dart without the rocker on.
No dimensions but will give you the idea. (I'm going with 10 per side, see last photo)
