[Found!] Dart Sport/Duster high back bench seat
weebull
north port fla.
Rating - 0%
0   0   0
I am looking for a high back bench seat with the fold down armrest. Going in my 74 Dart Sport so a 4 door won't work. Parchment or white preferred but will consider others. I will be going to the Nats in Aug. and can pick up there or along the way up or back. I'll be coming up from Florida. Thanks.
Four door seat bolts right in I have a black one and it will drop right in my Dart Sport no problem only issue is that you have to change the ring lock at the latch to a release lever …..
I figured there was a way to do it. I am hoping to do the least amount of work. That is a nice seat.
Remove the black plastic cover remove the locking ring install the spring latch with the nylon spacers cut a small slot in a plastic cover for the arm to pass through and then you’re all set the little
plastic knob on the end has to come off of the spring latch first this way you just cut a small slot in the plastic cover then you reinstall the knob back on.
