Princess Valiant
A.K.A. Rainy Day Auto
So I have a 75 dart and I decided to swap the doors from the original plastic trim doors with the heavy *** impact beams to the traditional metal top doors I had off a really messed up 71 dart.
After I got the door mounted with the hinges from the 75, it was spung a bit when opened. I adjusted the door gaps and alignment more and the spring in the door never went away until I removed the weather seal from behind the vent winder.
So that led me to believe the weather seal is different between 67 to 72 dart hardtop with the vent wing window and cars 73 and newer without the vent window.
I came in and looked it up and most vendors have the weather strip listed as 67 to 76.
Anyone done this swap before??
