[Found!] Dart - Window Regulator and Door Latch
billsdartgt
Puyallup, WA
Need a couple of parts for my drivers door on my 69 Dart
1st off, my drivers door is from a 68 - heres what I need:
drivers side window regulator 68
Door latch and associated parts/rods/etc. I would like to convert the door to the 69 setup which has the door lock rod further to the front, if that isn't possible then I just need the lock knob rod for the 68. The conversion seems simple enough even though the interior face of the door has different indentations, a few washers should do the trick.
I am in Boise so shipping should be reasonable
