Dash Radio Cut-Out Fix Ideas needed!
You could also cut out the offending area, weld a piece behind the opening, larger than the opening, a somewhat thicker piece even.
Then weld a thin gauge piece, same gauge as the dash, into the new 'hole' you cut out.
Prevents blow out when butt welding thin metal, and no one will ever know.
For the rounded section above the ash tray, same principle, use a piece of metal rod that fits the shape, stick it behind the dash, weld it up.
I've cheated like that before, some of this Mopar metal is just too thin from the beginning.
