I am working on the dash wiring in my 72 Duster 340. When I bought the car it somehow had a dash harness from a 73. I had the dash out and had worked on the dash wiring. Using a schematic, I had traced out and rectified any discrepencies. I put it in and hooked it up today. I have no rear body harness hooked up yet. The Problem that I had run into is that when I turn on the ignition, the turn signal flasher makes a noise as if the signals are on even though they are off. Nothing changes when I turn on the turn signal in either right or left position. the front park/turn signal bulbs do not light using the turn signals. The park lamps work fine. The black wire to the flasher is hot when I turn on the ignition switch. The red wire is not. I don't remember if that changes (red wire) when I use the turn signal. Black wire still remains hot. The flashers work fine.
I am also having some problems with the wiper motor. I haven't fully checked it out but noticed that it doesn't seem to have power to it.
I also have # six fuse blowing which has a large blue w/ white stripe wire and smaller blue wire comming from the other side of the fuse. Any help would be appreciated.
