Decoded the fender tag
Plaschy
Sweden
Filled out my fender tag info at http://www.dodgecharger.org/cgi/f67.cgi
Out came the following:
Car line PLYMOUTH Valiant
Price class Low
Body type 4 door sedan
Production date March 01, 1967
Shipping order 98114
Engine 170 1bbl 6cyl 115hp G [371/381]
Transmission Transmission-Torqueflite automatic [395]
Tires 6.50x13 black 2-4 steel (x5) [430/445]
Axle Axle-3.54:1 (9.75) -OR- 3.55:1 [406]
Trim Grade Base [32X]
Seat type Bench cloth&vinyl [331]
Trim color Red [34R]
Paint 1 Black [27B]
Paint 2 Black [28B]
Paint scheme Mono tone paint [291]
Upper door frame paint Dark red
Mirrors Moulding-lower body or applique [539]
Vehicle sales/delivery Sold car/expedite [691]
As you can see a low optioned Valiant. But, hey, what about the axle?
A misprint from the factory? Or a rare Valiant with a sbp Dana?=P~
Or is it just me filling out the numbers wrong?
The 6 under AX is for an open 3.55 8.75. No small bolt pattern Dana's. No non-Sure-Grip Dana's for that matter (in cars anyway). If it were a Sure-Grip rear, there would be an 8 after the 6.
Not beeing sarcastic: I also know there´s no sbp Dana´s. That said, what about the possibilities that: there´s misprint from the factory, or me filling in the wrong numbers?
Sure it could be a misprint. It is more likely that it has an 8.75 with open 3.55's though. What rear end is in it now?
CAR: Plymouth Valiant 4 Door Sedan
ENGINE: 170cid Slant Six
TRANSMISSION: 3-Speed Automatic
TIRES: Unknown tire code
BUILD DATE: March 01.
AXLE: 3.54/3.55 Rear Axle Ratio (Dana60 or 8 3/4)
INTERIOR: Red Interior.
PAINT: Monotone Black Paint.
OTHER:
MOLDINGS:
ABC OPTIONS:
abc OPTIONS:
p9: Unknown Option
u1: Sold Car When Built (Somebody Ordered It)
:dontknow:
7.25
I have been in contact with (nearly) all the 17 previous owners still alive. None of theme ever talked to me about changing rear end. But the Valiant have had at least 3 motor transplants over the years: from a 170 to a 225, then a 273 and now a 318 from a 1985 Dodge Van.
Most of the Valiants exported to Sweden, regardless what year, had a 170 /6 or a 225 /6 with a 7.25.
What are the chances of having a 170 /6 with a Dana anyway. Zero... I pressume.
