Decoding broadcast sheet
Hemiorangeswinger
Dodge Material
Edmonton
Hey I just got my broadcast sheet for my car and was wondering if you guys could help me decode some of it?
I can try and get some better pics but its really delicate and I don't wanna handle it to much... How can I tell if its a special order car? There is a 7 on the "sold to spec for" and I don't know what that means? Axle 019? I was informed by Joel that the first five lines on the broadcast sheet are the last digits of part numbers for the pieces used and I don't have access to those numbers and was wondering if anyone does?
I have had luck steaming them. I lay it on a flat screen type strainer about a foot over boiling water to add moisture to the paper. It helps get them to lay flatter without tearing.
The first line is ID information then 2nd through 6 is last 2 of part number.
next go here - download and copy over what you can to preserve yours.
[ame]http://mymopar.com/downloads/70_chrys_build_sheet.pdf[/ame]
car built on 922 Sept, 22 1969
Line 2
eng E55 = 340
Tran D21 = 4spd
Diff D53 = 3.23 axle ratio
Sure Grip D91 with a 1 = Sure grip differential
Tires - cant read?
trim code D2-X9 = 50/50 bench seat - vinyl, black in color
UDF TX9 = black upper door frame color
Paint style V01 - mono tone paint
Paint body and roof color EV2 - Hemi Orange
fan 15 = 2863215 18" 7 blade w/340
Carb = PN 3462968 Carter 4-bbl AVS, ID number 4933S (340-4-spd)
prop shaft = pn 2883758 for a833, 51.96 x 3"
wheels 12 x9 = 14"x5.5" black 2660312 color x9 is black
C23 Rear Armrests w/ashtray
wheel covers - W11, which I think we covered before part number 2944 435.
Wheels are 25 -
Thanks!! I'll definitly add all my codes to that sheet.. I don't know if I wanna try steaming them, haha. They are so delicate they almost crumble when you touch them. These were found in the back footwell area and were appearently soaked when they were taken out a few years back. I just carefully unfolded one of them and the lower part is all readable...
I scanned my broadcast sheet and printed out a copy. Not only does it keep me from handling the original but the scanner actually made it easier to read due to a better contrast produced by the scanner light.
Is that the only sheet you have? Some cars had 2 or 3 of them, try looking under the dash, I found one taped to the inside of the glove box liner on my 66 Valiant, some cars even had them under the carpet and in some strange places
I searched all over inside the car, the last place to look is between the gas tank and trunk pan but I highly doubt one will be there and if it is, it will most likely be worse then these. There are 3 build sheets total.. 2 with the quality control papers. The third one is very fragile and i dont know if i wanna seperate it completely. no need to since i seem to have a complete one between the two. I thought I'd never have this documentation. (Thanks to one of the previous owners hanging on to these)
Randy, this is the best I can do with information you gave. The broadcast sheet is different likely because this is a Canadian built car for Canada
John
Line 1
2048409
922 = September 22 1969
C03528 = ORDER NUMBER
L = DODGE DART, DEMON
M = MEDIUM TRIM GRADE
23 = 2 DOOR HARDTOP
H = 340 4-BBL
0 = 1970 MODEL YEAR
R = BUILT IN WINDSOR CANADA
100001 Not given = SEQUENCE NUMBER
Y(0?)7 = BUILT TO CANADIAN SPEC'S EH!
Line 2
ENGINE E55 = 340 4-BBL
TRANSMISSION = D21 = A833 4-SPD
AXLE - D53 = 3.23 RATIO
S/G - D91 = SURE GRIP
TIRES - T74 = E70x14" WSW
TRIM CODE - D2-X9 = 50/50 bench seat - vinyl, black in color
UDF TX9 = BLACK, Upper Door Frame color
PAINT STYLE - V01 = monotone paint
BODY PAINT - EV2 = Hemi Orange
ROOF PAINT - EV2 = Hemi Orange
STRIPE - V8X = BLACK BUMBLE BEE STRIPE
LINE 3
STEERING COLUMN - X9 = BLACK
STEERING WHEEL - X9 = BLACK
HORN PAD - X9 = BLACK
RADIATOR - 78 = 2998978 22"
INLET HOSE - 92 = 2863292 W/340 ENG
ALT - 72 = 3438172 (STAMPED) SINGLE GROOVE 37 AMP
FAN - 15 = 2863215 18" 7 blade w/340 (clutch type)
fan spacer 3?
BATTERY - 51 = P#3755151 - 48 AMP GROUP 24 W/GREEN CAPS
LINE 4
CARB - 68 = P# 3462968 Carter 4-bbl AVS, ID number 4933S (340-4-spd)
PINION - (33) 8.75/ 1 3/8 DIA P# 2931663, GEAR #2070611 SERVICE SET # 3432620 - 3.23 RATIO
DRIVE SHAFT - 58 = P# 2883758 for a-833 4-spd, Diamentions 51.96" x 3"
WHEEL - 12/X9 = 14"x5.5" P# 2660312, COLOR X9 = BLACK
SHOCK
FT - 54 = 3400854
RR - 94 = 3400594
FRONT BRAKES - 19 = is this K/H Disc Brake car?
LINE 5
TORSION BAR
LT - 893 = 2535893 DIAMETER .870, 120 LB/IN SPRING RATE
RT - 892 = 2535892 DIAMETER .870, 120 LB/IN SPRING RATE
BRAKE PEDAL - 12 =
CLUTCH PEDAL - 10 = 3575110 (STD DUTY)
TAIL PIPE
LT - 70 = 2925670
RT - 71 = 2925671
WHEEL COVER - W11 = P# 2944435.
WHEEL COLOR - TX9 = BLACK
WHEEL 25 - (SEE ABOVE)
LINE 6
A62 = RALLYE INSTRUMENT CLUSTER PACKAGE
LINE 7
H11 = HEATER W/DEFROSTER
C23 = REAR ARMRESTS W/ASHTRAY
C93 = CARPET
LINE 8
G41 = DAY/NIGHT INSIDE REAR VIEW MIRROR
F56 = ANTIFREEZE TO -35 DEGREES
F96 = OIL PRESSURE GAUGE
LINE 9
J15 = CIGAR LIGHTER
J64 = WOOD GRAIN DASH
LINE 10
M43 = GRILLE TRIM MOLDINGS
LINE 11
R11 = AM RADIO (2 WATTS)
LINE 12
S13 SUSPENSION = HEAVY DUTY with SWAY BAR
S25 SHOCKS = FIRM RIDE 1" FRONT and REAR
S31 = FRONT SWAY BAR
W11 = DELUXE WHEEL COVERS (SEE ABOVE)
Thank you so much!! :prayer:
How did you fill out the broadcast sheet? I suck at computers, haha
Here are the codes you had question marks beside.. If you have trouble with reading any let me know and I can check them and give you the code. There's also an anti freeze code for -35 (which is pretty much 8 months of the year) and another code 62 as seen below. I also got the stripe code.
Thanks again!!!!
Dang Rocky, you Rock!!! I should send you a copy of my 70 Swinger 340 sheet, I think I have a few unknowns too LOL
Keith bring it~!
updated BC Sheet. Other information updated above
Thank you for all of the information on this Rocky_JS I could use a little help with my Broadcast sheet too. Mine is just as bad, maybe worse. I was able to gather quite a bit of information from this, as mine has a lot of the same options. My car is a 1970 340 Swinger, with automatic, split bench and A/C .
I tried to leave you a message, but your inbox is full.
I hope you, or someone else here can help out.
I can forward a picture of my broadcast sheet, or post it in a new thread.
Thanks again.
Kevin.
[QUOTE="Hemiorangeswinger, post: 1970049606, member: 28116" How can I tell if its a special order car? There is a 7 on the "sold to spec for" and I don't know what that means? [/QUOTE]
Y07 is Built for Canadian sale.
Y39 is special order.
