moparspares
Hi Folks
My Hughes Cam is supposed to be installed at 107* When I installed my cam I had it in at 109* which is the best I could get it. I talked to Dave at Hughes Engines and he suggested a 2* degree offset key used on cam not on the crankshaft. I installed the 2* offset key on cam and now the cam centreline is at 105*
So the 2* key has advanced it 4 degrees from the 109*. Should I leave it there or try to correct with a timing set that has more adjustment.
