69dodgedart360
Sorry for the delay, I am approaching my finals for school and just haven't had anytime to really check timing, vacuum, or play with the jetting. Hey Mike! Yeah, I kinda feel like I should just take apart a 4160 series 750 cfm holley I have in my closet and swap them, but I will at least swap out things and see what happens. I jetted it down because I thought at the time that 76 and 83's were too rich considering my 670 cfm street avenger had much smaller jets and ran ok. This is the plan for the upcoming Turkey Day since I dont have school or work:
Check timing and adjust to see what happens
Check Engine Vacuum and change power valve if needed.
Test run with fresh gas.
After that switch from 72/76's to factory setting of 76 and 83 jets
Test run
If problem still is happening I was going to switch to a lighter vacuum secondary spring and try switching out springs in the distributor and play around with the timing.
I am hoping that with changing the jets and possibly the timing will help the issue but it is things like this where you really learn about tuning and your motor so even though my car is not running 100% where I would like it to be I am excited just to forget about school/work and tinker around with the car.
Thanks again to everyone for the information and advice!
Test run
