I had the same "problems" with the rear height on my Duster. I had the original tired leaf springs with coil shocks in them, bought them already. I liked the height, but since I was redesigning the entire chassis at the front, I also wanted new springs and shock absorbers at the rear. I then decided on the Espo, 6 layers, floor height. Built in, frightening! Way too high:-( Then I bought the Hotchkis, installed them, they fit, exactly the height I wanted, but I had the problem that the shakers pointed too much towards the rear, and the shakers hit the chassis with the slightest bump. So I bought 1.5" lowering blocks and put the Espo back in. The height is absolutely fine, but I don't have much space between the shaker and the chassis here either, almost like the springs are too long. Spacers are not installed on the front hangers. The Espo should be a little tick softer, I'm not that much of a fan of lowering blocks. Does anyone know of an alternative spring? Otherwise I'll ask Espo if the 5 layers are also 1.5" lower
