[SOLD] Diamond W-2 Top end and rockers
dadodgekid
When in doubt... floor it
Palm City , FL
im selling a nice pair of Diamond W-2 heads (these are aluminum) a port matched victor intake (4150 flange) , a street dominator W-2 thats been opened up for the rec. intake port and (4500 flange) , and a set of used Harland sharp rockers for W-2. Please remember these are used parts, not new pieces and will need some attention. I have the valves out of the heads and glass beaded them for better inspection. Titanium retainers, valves and keepers in good shape, but remeber all parts are used. Ill attach pictures later, but i do know these are very rare and I dont have the time to build another motor to support them. $1500 plus shipping. I only ship FEDEX due to problems with USPS. Thanks FABO!
EDIT- here are a few pics, ill get pics of the intakes and rockers by wednesday
2.02 but i need to double check and i did pressure test and glass bead them a month ago and no leaks... double checked valves are 2.02/1.60
Ok I thought so those were my old heads I went low 10 with those heads 340 block 3.79 crank and 259-266 flat tapper those heads do make some good power they get very noisy on the bench above 310 @600 but do make power someone will get a nice set of heads what did you do for the rocker arms oiling are you still piling them off the back of the heads
I'm sure they had a 208 when I ran them the ones on Ryan's web site are my old heads you just don't see many of them come up for sale the intake port is big on them that's for sure for a head designed in the early 80s
All the exhaust bolt holes have helicoils, the rocker stands have threaded inserts. A couple intake bolt holes need helicoils.
Im going to have the heads sent up too shaddy dell so ryan can get these heads in tip top shape. Off the market for right now...
No sir, they are just like the pictures above. Lots of life events are catching up, and I cant spend the money to use these. So they must go. Ive got to replace an A/C unit at my new place. So watch for other deals soon!
