69signetv8
For you math guys or just in the know:
I kinda think there's a differance but I'm not 100% sure.
Since my 273 was rebuild and now pulled, I have noted that I have put on 21,886 miles in the past four years. I had 391 gears through out this time and didn't change the speedo gear (me bad). Due to this...of course speedo indication is different, that I know (like showing 85 MPH when only doing 55 MPH. Question: Does this mean my true mileage is recorded higher as well (like a mile is no longer a mile but shorter :scratch: If so....what would you "guess" as a closer true mileage number with my info above??
Added info: 28" tires and "about" 3200RPM @ true 55 MPH
Anyone want to try to figure.
Cheers and Thanks
Cheers and Thanks
