bighammer
Wth? This question is in regards to my LA 360...
So I swapped out the truck pan for a car pan, I'm assuming that's part of the reason for the different lengths of dipsticks (?)
Anyway, as you can see in the photo below, the l o n g dipstick is the one I removed from the truck application. The shortest (chrome) one is one I picked up from a website, I forget where. But it is about an inch shorter than the used take-off I bought from a member here (the other orange painted tube) My best guess is the used one I bought from a member is going to be correct, but I don't know if it was from a 340 or 318. Are they the same?
Can you provide me with the correct measurement of the dipstick with this 360 car pan? Due to different length of tubes, the measurement I will need is the distance down into the block the stick will need to be inserted, regardless of tube length.
Thanks in advance
Thanks in advance
