Jhenry70
So.... Feeling kinda dumb right now. I've got my front end apart and I'm gathering everything to go back together with BBP front disc brakes. Oh yeah, it's a 72 Duster. I've got stock UCA's and LCA's with 1977 Aspen spindles, hub/rotor and calipers. I'm using the stock upper ball joints with Dr Diff taper adapters and 1973 and up lower ball joints.
Here's my head scratcher, I know I need to get longer bolts for the lower ball joints to mate them up with the 77 spindles. But as I'm laying it all out on the bench I see that both the spindle and the lower ball joint mounting holes are both smooth bore, no threads. I had thought the ball joint holes were threaded on the donor car? Maybe I just spaced it and didn't grab the nuts or they got lost somewhere along the way. So am I correct in just buying the longer grade 8 bolts with nuts and locking washers to attach the lower ball joint???
Have I been staring at it too long, too tired or am I just missing something?
Help!!
Help!!
