[SOLD] Disc Brake Ball Joints
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
I have a pair of either NOS or NORS disc brake ball joints that use the larger 9/16th ball joint bolts and nuts to secure them to the spindle. I was going to use them on a 65 Barracuda I had; however, the car is long gone. One of the boots is missing and will need replaced. Rock Auto gets anywhere from $42 to over $70 per lower ball joint for 65-72 A Bodies and don’t specify if for drum brakes (1/2 in mounting hole) or discs (larger 9/16th mounting hole). I guess these could be used on a drum brake spindle if the mounting holes were drilled out to 9/16th. I would like $50 for the pair plus shipping from 22657
Nope! These are for the late 65 - 72 disc brakes. Other than the larger mounting holes, they are dimensional the same as the drum brake ball joints
I have a tentative sale on the ball joints. Upon receipt of the payment I will update the ad.
