Jan 22, 2012 #1 M Mopar Joe V New Member Joined Jan 22, 2012 Messages 3 Reaction score 0 Location Long Island N.Y. Do I have to change the control arms to install a Old style disc Brake Setup. I have rotors/spindles/calipers/booster.
Jan 22, 2012 #2 daredevil Well-Known Member Joined May 19, 2007 Messages 10,984 Reaction score 262 Location S/w Houston depends on ball joint size,dont think so unless you use 73 up spindles.
Jan 22, 2012 #3 65 Dartman 1 of None 65 Dart Sedan Delivery FABO Gold Member Joined Sep 24, 2006 Messages 14,638 Reaction score 5,582 Location Strasburg, VA If you mean the 66-72 Kelsey Hayes set-up, reuse your original control arms. Be aware the lower ball joint is different than the drum ball joint.
Jan 22, 2012 #4 M Mopar Joe V New Member Joined Jan 22, 2012 Messages 3 Reaction score 0 Location Long Island N.Y. Thanks I will check that out, I think the setup is a 1966 or 1967
