[SOLD] Disc brake swap stuff...large bolt pattern
Jimacuda
Legandary Member
Legendary Member
Phoenix AZ
I have a 10.9"(approx.) disc-brake set-up from an F body (Aspen/Volare) available, bolts right up to a 67-76 A body (using either large ball joint upper control arms or DoctorDiff ball joint adapters).
May also fit earlier A's.
Includes: spindles, dust shields, very good rotors, caliper brackets, slider type calipers, distribution/prop valve and master. Everything was removed from a working brake system. Calipers and master are good but included as cores for exchange.
It includes everything pictured. What you see is what you'll get.
$200 plus shipping. (approx. 100 lbs.)
Fits in 3 USPS large flat rate boxes for $60 insured to most US address.
Local pick-up in Phoenix, AZ.
Thanks FABO!:thankyou:
(for replacement calipers, rotors and pads use 1980 Volare wagon w/318...better bleeder location)
(lower ball joint- pick any 73-76 A body, disc/drum same bj)
