[SOLD] Disc Brake System
Zak
Valdosta, Georgia
Complete disc brake system for 70-74 A body. Came off Duster. Large bolt pattern new rotors (4.5). New calipers..new pads...Good lower ball joints.. No dent shields. All hardware to include brake lines. Went to a kelsey 4 piston system. $300 plus ship on your dime.
Could you get a quote on shipping to 63301? I may be interested. Thanks.
Ok...gotta do alot of boxing up safely/securely and bring to UPS or USPS. Probably middle of next week if your ok with that bb....john
If you leave the rotors out, and disassemble the caliper brackets and lower ball joints from the spindles, you can probably get all of that stuff into two large flat rate boxes without exceeding the weight limits, which should ship for around $53. Even if it took 3 it would be under $80, and honestly 2 should work.
Just an FYI if it helps with your sale. I've shipped spindles that way before, it takes a little finagling to get them arranged in the box but it does work.
Agree 100% many years ago, I had a member here ship me both rotors, spindles, brackets and calipers, for the 69 Fury I use to have, in 3 large flat rate boxes
