I have a 71 Duster manual drum brakes. I would like to swap to power front disc and leave the drums on the back. What all do I need and what would be the most economical way to go? Thanks!
I got a full kit with everything through summit from a place called classic performance parts. It was expensive but it came with absolutely everything. Spindles, a-arms, lower ball joints, discs, calipers, brake line from the caliper, booster, master cylinder, fittings, proportioning valve (you get the idea). The only other thing I bought were new lines from the PV to the junction box and those fittings. Here is the link to one on summit that uses your stock spindles: http://www.summitracing.com/parts/clp-a6374cbk-s/overview/year/1971/make/plymouth/model/duster
This is the same kit I use on my cuda and once I got my rear drums sorted out I loved it. It works great!
