71DartGuy
I have a 71 dart with drums all the way around. I just bought the front disk brake setup from a 73 dart. I got upper and lower control arms along with the spindles. I found that the lower ball joint is attached to a cast piece and is one complete unit on the donor parts. Can I use that same assembly from my 71 or will it not bolt up to the 73 spindle. I hope I made myself clear enough. If not, which year spindle should I be buying?
