Disk Brake Conversion
dart67
NH
When you put the front conversion to big bolt the caliper interfers with the sway bar because it is on the front has anybody used the volarie calipers and put them on the back like they are on the small bolt pattern disc brakes?
Thanks
Mike
Can you swap driver side to passenger side on the spindles so the bleader is up?
Thanks
Mike
Yes you can swap the spindles side to side. You also need to swap the calipers side to side in order for the bleeder to be up. You will need to use the Volare/Aspen brake hose though. The 73-76 brake hose is not long enough when you swap sides.
