Disk Brake Interchange?
jeeper
Klamath County, Oregon
I have several Volare's that are collecting in the back. What parts interchange with A bodies for a disk conversion? I know that you need an a body specifc piece or two, but what will interchange?
Thanks, ROB
The rotors, bearings, backing plates and calipers. Some say the whole assembly as in spindle, backing, bearings, and calipers. But there is a big controversy over the spindle. As it's about a 1/2" taller than the standard a body spindle. It's taller due to the front end of the Volare type front end being rubber isolated. Just use a search on spindles and you can read all about it.
