Moparbrad
You don’t know me
Complete big bolt pattern (4 1/2in) disk brake conversion with power booster and mounting brackets, master cylinder, good rotors, backing plates, calipers, spindles, brackets and hardware, upper control arms and proportioning valve. Everything you need but the 2 steel lines that go from the master cyl to the prop valve because I sold em.
$300 will not seperate any parts
8 1/4 with 4 1/2 bolt pattern for a body. It has 10in drum brakes and I will include the leaf springs and park brake cables. Has 3.21 gears open, no sure grip!!
$300
Im not shipping this stuff, it will cost tooo much! If you know some one that could pick the parts up, that would be better. I can deliver to Phoenix Area for gas $$$
PM me
$300
PM me
