DonPal
Slants eventually upgraded from a slotted distributor plate to a distributor clamp style similiar to small blocks.
Slotted distributor clamps limit the adjustment so if you pull a distributor & reinsert it on other than the perfect gear tooth...... adjustment is near impossible.
Since I can get small block clamps easier than slants I'd like some dimension of a small block clamp to see if it would work....a picture with dimensions would be helpful.
Thanks.....Don
Thanks.....Don
