dartfreak75
Restore it, Dont part it!
Hey guys I have a couple question about my distributor setup. Ok my car is a 75 i have the orginal mopar electric ignition box with the ballast resistor setup. My engine came out of a 86 with an ecu mounted on the fendewell im assuming it has some kind of electical advance cause the distributor does not have a vacuum on it. My question is can I run the 86 distributor with my old wiring (the plug in is the same iv checked) without a vaccum or should i get a distributor with a vacuum advance ? Also I found a distributor to bypass all the wiring and ecu stuff its a vacuum advance hei system it says all it needs is a 12v power supply and a coil to run. Does anyone use these? Are they any good? Is it more reliable and perform better that the factory control box? Thanks
