Ditch the Power Steering!?!
73Dart340Sport
73dart340
Colorado
I would like to get rid of the power steering in my 73 Dart 340 Sport. In addition to taking up cubic acres of space, it is well worn. Any suggestions?
Thanx!!!
First you need a manual box.Junkyards,e-bay,swap meets etc.
Flaming river has a trick unit but pricey.You will also need a adapter if you are going to stick with the same power steering column.Or install a manual column.The adapter seems easier.I cant remember if they share the same pitman arm.Either way that's simple to figure out.
Take the power steering parts out,install your new manual parts and your done.
Hope this helps.
