Do 68-69 horn pad adapters interchange?
Golden Scamp
Topeka
I was needing to know if the horn switch will interchange from the stock 68 Dart steering wheel to the 68 Woodgrain wheel? I have the horn pad and woodgrain wheel but wanted to know if I am going to be able to pull the old wheel and use the same horn switch. I do know the horn pad adapter won't work. Has anyone done this swap? Thanks
