i jus dropped a small block into a org 6 cyl 1970 duster.... i used all original V8 k-member and so forth.... i am running a new 26 inch 3 row radiator from a 1 ton truck (overkill) with shroud, 160 mr. gasket thermostat, 8 blade water pump, and a 5 blade clutch fan... now i found this lo-pro fan part number on here and i got it....the clutch is for a 90 XJ7 Jag.....
The car likes to run around 180-200 in the heat and hills....and right about 160-165 on faltland cold nites:thebirdm:....do i need a diffrent clutch for that 160 thermostat id like to run??
i think i have 3-3.5 inches from face of water pump pully to face of radiator...
any help would help....thanx!!
