33IMP
On the other hand.....this can happen with transbrake use.
That’s exactly what u wanted to hear. To have someone agree with u. Good luck 2ya. Kim
A trans brake is too rich for me
Thanks
That’s why u get a converter built for use with a trans brake. Well except for 70aarcuda. KimOn the other hand.....this can happen with transbrake use.
One of the reasons, steel stators are now available, for use with a transbrake and/or nitrous.On the other hand.....this can happen with transbrake use.
With the power you are throwing at it you do not need a nitrous convertor.
If it can take the full hit right out of the gate and you don't have to use a nitrous controller or activate it after your 1st or 2nd shift, the only thing you may see is a little higher flash on the stall speed which won't hurt anything.
The busted up one was one that i had laying around. The custom munsinger transbrake converter i replaced it with was two tenths and four mph better,....in the eighth.That’s why u get a converter built for use with a trans brake. Well except for 70aarcuda. Kim
For sure for sure. KimThe busted up one was one that i had laying around. The custom munsinger transbrake converter i replaced it with was two tenths and four mph better,....in the eigth.
