do i need a special bolt that connects by brake pedal to master
Special one, but you can rig up one as long it it won't bind and can have a bit of play and still stay tight.
I may have one.
I believe it also has a self locking nut.
I think the diameter of the bolt is exactly enough to spin in the pedal and actuator rod but not small enough to **** or bind.
It looks like a seat belt bolt with a shallow, radiused head, but the shaft diameter is larger.
Bet 80's models from a u-pull would work.
