[SOLD] Dodge 360 LA engine
Eric Pearson
73purpule duster
Houston Texas
Selling a Dodge 360 engine that came out of a 1974 Dodge Dart Sport. This is a complete and running engine. It has 340 X Heads that have hardened valve seats and bronze valve guides. Dual valve springs. ARP head studs, Eldelbrock Tourqer II 340 manifold,Holley 650 Double pumper carburetor, it has a mild cam and Rhodes lifters. Double roller timing chain. Mallory Unilite distributor and coil. Melling high volume oil pump. Factory windage tray. The complete bottom end is 1974 stock.also comes with a alternator and brackets. 10.5 Zoom clutch and pressure plate.
$ 2500.00 local pick up only
Is that the coolant outlet that was always on the engine or did you change it out? Thanks
Does it have a hardened intermediate shaft?
How many miles on it?
Is it bolt in an go ready?
Or does it need freshened up first?
What is your guess on hp?
Have you ever run it at the track?
Shaft is factory. Miles unknown.I’ve had this motor since 1980. It is able to bolt in but I would definitely freshen it up. Hp guess around 300ish. And yes I ran it at the track years ago. 13.43 et with 3.91 gears. I just removed it yesterday from my Duster
When was last time you had it running
