[SOLD] Dodge Aspen w/Magnum Force suspension project.
migsBIG
San Jose,CA
For sale 1978 Dodge Aspen Coupe project that was being built for Performance driving. Car started out as a clean original CA car that was stored away in the 1990's when the original owner died. Very straight and nearly rust free car (a little rust started in the lower rear quarter panel) and looks like it was never in an accident. Burgundy bench seat interior looks nice and could still be used. Car was taken tot Magnum Force Racing for suspension upgrading. Recently had a full "Transformer" CUDA/Charger style front performance package done on the frontend which is a heavy duty custom crossmember, fabricated chrome-moly tubular upper control arms, powder coated blue k-member, heavy duty lower control arms, Swaybar package, 15:1 ratio power steering, double adjustable coil over shocks, 2in forged dropped Mopar spindles (1973+ large bearing type) small motor mounts (big block motor mounts & later style hemi mounts cane be used on this suspension ) and Wilwood hubs are installed so it could be rolled around easily.If someone wanted to this suspension, it would fit bolt onto1966-74 B/E-body models and would just need the upper control arms changed and they could sell off the body to re-coupe some cost. Have not tried to start the 318 engine as I was going to install a 550hp engine, but its all there. Steers fine, rear brakes still hooked up so it can still use emergency brakes and transmission can still be shifted from the column to help stabilize it for transport and storage. I have a friend who does transport and can do west coast/Cali quotes for those that can not pickup in San Jose, CA. If a foreign buyer is interested, I can also get quotes for shipping to ports in San Francisco, Oakland and Los Angeles which is usually in $250-$500 range. Have clean pink slip. Rally wheels are not included and a set of ugly, mis-matched junky rollers will be on the car. Located in San Jose, CA. came out to $6,000 in parts alone. Since Magnum Force installed the front end, that was another $2000 in installation costs. The Value of the car since it's soo clean and complete was another $2,000 making this a $10k project car. Sadly, got to move on decided to let this one go. Price is 1/2 at will sell for $4995 That pretty cheap for most of the hard work done. I am not looking to trade it at this time.
