Big.J.007
I have for sale a very good used Dodge Chrysler Plymouth Mopar 8.75 8 3/4 Powr lok 4 pinion Sure Grip Posi. This Unit is dated 7/31/67. It has all original internals in excellent condition. Nothing from China here. This unit has New Yukon Aggressive clutches in it. Everything is torqued down to factory specs using the Fsm. Red loctite on the case bolts. These are the very best clutch type posi you can get. And with these clutches you get as much lockup as having a spool. But no cornering problems. This unit requires 2 bottles of Ford friction modifier. It is bolt in ready. All you need is to install new carrier bearings. I went a different direction on my build so I'm selling this. You Mopar Guys know how hard these are to find. If it doesn't sell I will keep it for a future. 450.00 Shipped in the Us.
